Hi All,
I have a DDM 4000 and i just noticed this issues... im not sure if its normal or not, so please if its normal, let me know and put my mind to ease :)
When I use the Sampler function, say I record in a 2 second clip (lets say vocals) and Play/Out the sound, and the end of the sample, a sort of crackle or pop type sound is made...so if i have a loop sample thats 2 seconds long, after each sample, a crackle is heard over and over and over again at the end of each clip.
Is there a setting i need to check with...im currently using the mixer as external for testing purposes, but this issue comes out when using VDJ as well...i believe its a mixer issue and not VDJ related.
So anyone have this same issue? is it normal? what to do!
Thanks!
Thanks!
geposted Wed 09 Mar 11 @ 3:28 pm
I haven't experienced anything like that with my DDM4000...
Sorry I cant be more help.
geposted Wed 09 Mar 11 @ 5:42 pm
Shucks! I dont think its a setting, maybe my mixer is toast...i only put about 2 hours on it.
geposted Thu 10 Mar 11 @ 6:58 am
i think i may have sorta solved it... please someone confirm...
OK so when i sample a song and get a "crackle" or "pop" sound its usually when the slider volume it set low for that channel. But if i increase the volume slider for that channel when sampling the "crackle" or popping noise at the end of the sample cease to exist. Anyone confirm that, please?
ALso, im fairly new to the DDM4000... but can i control the volume independently for the sampler?
geposted Thu 10 Mar 11 @ 1:08 pm
