Sorry for the dumb question probably an easy solution.
How do i get my korg nanokontrol to show up in virtual dj. My hercules controller works just fine but the kontrol isnt recognized.
I installed all the drivers and software for the nanokontrol.
thanks for the help
thanks for the help
geposted Wed 09 Mar 11 @ 11:34 pm
Your LE software is not designed for other midi devices. The Herc controller is mapped in the software but your nanokontrol is not. You will have to upgrade to the Pro version for that to work.
Best of luck,
AC
Best of luck,
AC
geposted Thu 10 Mar 11 @ 1:02 am
I'm using VDJ pro-basic ver with MacBookAir.
can't recognized Nano Kontrol at mapper section only keyborad
already installed korg driver ..
please let me know guys
geposted Sat 07 May 11 @ 4:13 am
superaceman wrote :
You will have to upgrade to the "full" Pro version for that to work.
AC
AC
geposted Sat 07 May 11 @ 4:15 am
Thanks
geposted Sat 07 May 11 @ 4:38 am
