hello going to buy vdj pro full but dont really want to get an all in one controller if possible, i was wondering if i could instead use the Numark C3USB to have control of the vdj software.. i know this has been posted before but can not find an official answer. thank you. (says the usb has input and out ports)
geposted Thu 10 Mar 11 @ 4:26 am
by the look of the specs on numark page you can use it with VDJ as a sound card but you wont be able to control VDJ from it.
geposted Thu 10 Mar 11 @ 6:06 am
The C3USB has 2 USB-soundcards on board. They can be assigned to Deck 1 and 2 so you can run 2 iindependend decks. On the mixer the USB-cards can be switched to input or output. This means that 1 USB-port can send OR recieve, not both at the same time. You can switch the USB-ports individually, so recieving via 1 port and sending through the other is no problem.
The mixer is not a controller.
geposted Thu 10 Mar 11 @ 7:52 am
