Hey!
I´m new in Virtual Dj. I´m wondering how can I hear one deck in my earphones and the main deck in the speakers. I use an audio splitter. The problem is that I hear both songs on the speakers. I tried to change it in the configurations/sound setups/outputs, but it dosent work. Is it possible in my laptop to mix using only a audio splitter or do i need also a USB soundcard?
Thanks!
Thanks!
geposted Thu 10 Mar 11 @ 9:55 am
Not sure what you mean by a splitter, I am assuming this is standard laptop soundcard setup. You need either a usb sound card -you can either use a cheap single channel one which will manage low power head phones or there are usb soundcards that have a powered output for a set of DJ headphones as well as a decent quality audio output - if you are just a bedroom dj then the first will surfice, if you are going to be using system for pro work in the future then invest in a reasonalbe usb soundcard. The laptop audio out is not bad but not equal to a stereo line out in quality or response pattern.
Also before posting questions have a look to see if topic is already covered on here - this will be somewhere - moderators will shut down repeat posts as it saves reposting answers that have already been asked
geposted Thu 10 Mar 11 @ 11:24 am
Thanks for the answer. By the splitter i meant a small cable that you can connect into your audio input that has two cables coming out with two outputs. That is how i can connect speakers and headphones at the same time to my laptop. Guess that the splitter is not the solution for my problem and i have to buy the USB soundcard. Am i right?
geposted Fri 11 Mar 11 @ 9:36 am
Yeah that's easiest and best way. You can find a cheap one for like 25/30 bucks on eBay, I found one at my local pawn shop for 10 bucks.
Huey
Huey
geposted Fri 11 Mar 11 @ 9:42 am
You may have the wrong type of splitter cable. You need a splitter that splits a stereo output into separate mono left and right. You probably have a splitter that splits a single stereo output into two stereo outputs (E.g: To allow two headphones to be connected to the same music player.)
However, a splitter cable will only give you MONO sound.
Adding a simple external stereo USB sound card as advised above will give you a stereo output for your headphones, with your computer's own sound card being used for your master output in stereo.
geposted Fri 11 Mar 11 @ 12:33 pm
Thanks for the advice
geposted Sat 12 Mar 11 @ 11:44 am
The best explanation about using an audio spliter for laptop mixers is here:
http://ourmancave.wordpress.com/2011/08/18/a-mobile-dj-setup-dj-while-stuck-in-traffic/
You need a very specific type of splitter and an adapter from Radio Shack in order to get two channels out of the laptop's headphone jack.
geposted Fri 16 Sep 11 @ 2:44 pm
