Hi,
I wanted to use my DN-X1600 as my only midi-controller (always have used it with an Xponent on a gig) but I ran into this problem. Can someone please help me? I didn't have this problem when I was still using 4 separate buttons to select the active deck.
Thanks
Jodi
Below are previous pms about this issue
To: djdad
Sent: Thu 06 Jan 11 @ 8:18 pm
Subject: VDJ Script Help
Message:
Hi Bob,
I really loved the vdj script you posted for toggling player-loops-effect control panel that works on all 4 decks.
Can you create a script that toggles the active deck from 1 to 4? I want to use this to save some buttons for other use on controlling my Denon DN-X1600, instead of assigning 4 individual buttons for selecting deck 1, 2, 3, & 4.
Thanks in advance!
Jodi
Sent: Fri 07 Jan 11 @ 1:02 am
Subject: Re: VDJ Script Help
Message:
Hi Jodi,
I can help you out, but these things are better to be posted in the forums to help other users as well.
Try this
deck 1 select ? deck 2 select : deck 2 select ? deck 3 select : deck 3 select ? deck 4 select : deck 4 select ? deck 1 select
it will cycle the selected deck from 1 to 4.
Greets
Bob
Thanks
Jodi
To: djdad
Message:
Hi Bob,
Thanks in advance!
Jodi
Message:
Hi Jodi,
Try this
Greets
Bob
geposted Thu 10 Mar 11 @ 1:59 pm
Never mind...'figured it out.
geposted Thu 10 Mar 11 @ 8:49 pm
