So I have been looking at purchasing some speakers and I was trying to decide which is the best way to go about it. Powered or non powered?
No powered, I can get an amp but I am looking at more stuff I have to carry & probably a little bit more money I have to spend. Not only that, amps to to blow and have other issues. Then again I can go with powered and be worried about issues with the amp in the speak and maybe dropping them and then costing me.
Then when I look at it, it is all the same but I do linke having less to carry if i am going to do gigs.
How is it best to have my speakers? On poles, with a sub, or without?
I am ready to spend a few thousand and I am usually really slow at buying big ticket items so I want to make sure I do the right thing before I take the plunge.
Also which brands are best because I am attracted to Peavy, Mackie, CVs and JBLs.
Fill me in on your knowledge.
geposted Fri 11 Mar 11 @ 10:43 am
I have been looking at moving to powered speakers but it will be a while here are a couple I have been looking at
[youtube]03pVt6lqdHE&feature=feedu[/youtube]
But I am a fan of Peavey speakers and at 1200 watts these have my interest
Depending on the bottom end of either set, if needed I would have a single dual 18" powered sub cab centered between the two that were mounted on poles.
geposted Fri 11 Mar 11 @ 10:59 am
Those were good reviews. So just from the sound of the first video I am needing anywhere from 750 to 1000 wats apiece. So far, good info.
geposted Fri 11 Mar 11 @ 11:22 am
Get Behringer or Mackies.
geposted Fri 11 Mar 11 @ 11:48 am
I've used these at countless of gigs and have been very happy with the tops. I have 4 for big rooms, but usually only need 2 on stands for a room that holds up to 200. I pair the tops with a Mackie SWA1801z portable sub. I've been very satisfied with the results.
geposted Fri 11 Mar 11 @ 11:53 am
