Hi im new to the forum and also just moving over from cds to laptop. im using a behringer bcd 3000 controller with vdj 7 pro, but having a few issues with the controller, after having bought it i now see that maybe it wasnt the best for the job, but however as always im on a budget and cant afford to buy another controller... so ill deal with it! ( hopefully)
there are a few problems which are as follows:
1- when i turn on key lock it applies to both decks and as i move the pitch slider it moves on both decks and still varies the pitch of the vocal???? has anyone else experienced this and know how to sort it
2- next is the set cue, st loop, reloop sync and scratch buttons above the crossfader, the only one that seems to be doing its job properly is the scratch, however as i dont scratch this is irrelevant :)
im just getting a bit frustrated at the fact i bought this to save fiddling around with the laptop and its not doing what it should, hopefully one of you guys (or girls) can help me out
cheers,
Brian.
cheers,
Brian.
geposted Fri 11 Mar 11 @ 10:47 am
