I rely heavily in the rating system, (even though VDJ will not read the rating ID3 tag), and from time to time the Stars will dissapear and get replace but what it looks like a small "square", in other words the font seems to change. After several re-starts it self-fixes again. Is this a bug or I am doing something wrong?
geposted Fri 11 Mar 11 @ 1:00 pm
At least you get them back, I have never seen the stars only squares instead.
geposted Tue 19 Jul 11 @ 8:03 pm
I have never had them on xp, but windows 7 is fine, its probably a compatability issue with xp
geposted Tue 19 Jul 11 @ 10:33 pm
I have the same problem. Has anyone found a solution for that? For a while the stars where there, now they are gone or replaced by little squares.
geposted Sun 18 Sep 11 @ 2:44 pm
