Forum: Old versions
Topic: How to change the internal crossfader slope in VDJ
Hello, I;m wondering if there was some way to change the internal crossfader slope on virtualy dj....I've wanted the hercules RMX crossfader to be like a scratching crossfader but i can't find any information online about how to do that...
geposted Fri 11 Mar 11 @ 6:32 pm
Sorry, this is not possible in VirtualDJ LE that comes with the DJ Console.
VirtualDJ Basic that you also have registered does not support using MIDI controllers.
If you upgrade to the full VirtualDJ Pro at a discount by going to https://virtualdj.com/buy/ you can then change the crossfader curve in CONFIG -> Options. You can also customise the mappings of the RMX via CONFIG -> Mappers
Assuming that it is not second hand or the discount has not already been used, your RMX DJ Console entitles you to a significant discount off upgrading to VirtualDJ Professional. To receive this, please go to https://virtualdj.com/buy/ and enter your DJ Console software serial number in the box provided.
I'm thinking of buying that pro version of Virtual DJ but I want to know in advance if it has those capabilities......
Nevermind, I read your message again and i saw how to change it.....Thank you for your help!
You can try it out in the 20 day trial of VirtualDJ Pro build into VirtualDJ LE, or if you have already used this, you can try it out for 10 minutes at a time in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
