VDJ works fine, however, I can't install any plug-ins like video transitions. Everytime I try, it says "No Software Found".
I have an idea of where the problem is. I bought a laptop "off the floor" of HHGregg...at it had the username of "ST0212"...so I took the laptop home and installed VDJ 7.xx with much excitement to make sure it worked for the videos. After a day, I decided to change the username to "DJ Johnny A", then I switched back to "ST0212" cause I was afraid it might affect software installs.
Any ideas?
Any ideas?
geposted Sat 12 Mar 11 @ 10:47 am
reinstalling the software on the current login should solve the issue
geposted Sat 12 Mar 11 @ 11:19 am
The issue is still there after a reinstall. I was able to install one video transition plug in, then the next install said "software not found". Any ideas what it could be?
geposted Wed 23 Mar 11 @ 3:04 pm
Read a temporary solution here
https://virtualdj.com/forums/144671/General_Discussion/Skins__Effects__etc__saying_VirtualDJ_is_not_installed.html
There will be a fix in the next update.
geposted Wed 23 Mar 11 @ 4:35 pm
Yep, that fixed it...thanks!
geposted Wed 23 Mar 11 @ 10:55 pm
