Hey everyone,
I'm experiencing a strange issue with the free version of virtual Dj7 (v 7.0.3). The cross fader is not responding. I can click and drag it or use the page up/down buttons to move it but it will not fade between songs. I have tried re-installing, restarting my computer, and uninstalling other dj softwares (ITCH, Mixxx, Scrath Live) but nothing seems to work.
I am currently using the factory setting for everything, no controller, no external sound card, simply software and computer speakers.
I am using Windows 7 (64 bit)
Please help if you can, any suggestions are greatly appreciated.
geposted Sat 12 Mar 11 @ 10:56 am
Go to CONFIG -> Options and make sure the crossfader is not disabled.
If using the 4 deck skin, make sure that the correct deck has been assigned to the left/right sides of the crossfader (Click on the numbers 1, 2, 3, 4 to the left and right sides of the crossfader to choose the deck assigned to each side.)
geposted Sat 12 Mar 11 @ 2:43 pm
thanks for the help. It turns out it had disabled it self some how and i did not know how to change it.
this thread can be closed/locked if needed.
geposted Sat 12 Mar 11 @ 6:29 pm
