Hey, I tried searching but could not find the answer i needed... I have a couple playlists made in VDJ, but i can't seem to figure out how to edit them/add additional songs. any help?
geposted Sat 12 Mar 11 @ 11:54 am
-Click on the playlist you wish to edit
-add and remove songs in the playlist sidebar at the right side of the browser
-click SAVE in the playlist browser
Hope that helps
AC
Hope that helps
AC
geposted Sat 12 Mar 11 @ 2:44 pm
yea my problem was every time i would click another folder, the playlist would go away. but if i add the songs first, then click "merge playlist into window" it works. thanx :)
geposted Sat 12 Mar 11 @ 5:39 pm
put your playlist in the automix window on the right and then edit as much as you want, and then save it
geposted Sat 12 Mar 11 @ 7:06 pm
If you want to edit a playlist, click on the playlist you wish to edit, then go to Config-Options and set ...
AutoLoad Playlists .. Disabled
Now you may use search, navigate through various folders, move, add, remove and the playlist will remain in the window.
After editing and saving, it would be better to set to Smart again.
geposted Sat 12 Mar 11 @ 9:00 pm
