Forum: Old versions
Topic: skin load error
I keep getting an error saying I am trying to load a skin that is not compatible with my computer. It will give me an option to hit ok or cancel. Either option just throws virtual dj into a corner and can't be used. Could really use some help on this issue3
geposted Sat 12 Mar 11 @ 1:38 pm
should be noted that i have an older computer right now. so an older version might be best. Just want to play around with the free version before buying a new computer and moving from cd's to lap top
A skin designed for a newer version of VirtualDJ (E.g: v7) won't work with an older version (E.g; v5)
Also, skins are only available to registered licensed users: https://virtualdj.com/products/comparison.html
Skins that have been downloaded from unofficial sources may not work correctly.
