hey
im using vdj with my m-audio connective. ii need info on how to record using this setup without the cueing being heard during the mix. i make sure my fader is over on the deck that i want to play but when im cueing on the other deck it come thru on the recording, it dosent come through live. worked at it about 4 hours and decided it beat me so im asking for help.
thanks
keith
thanks
keith
geposted Sat 12 Mar 11 @ 4:00 pm
You'll have to be a bit more specific on the configuration of your set-up. Are you recording internally or externally?
geposted Sat 12 Mar 11 @ 4:08 pm
im recording internally. what other specifics do i need to to post.
thanks
keith
thanks
keith
geposted Sat 12 Mar 11 @ 11:10 pm
Have you tried recording your mix by using the volume faders on the decks and leaving the crossfader centered?
It's definitely a strange situation.
geposted Sun 13 Mar 11 @ 4:01 am
yes i have tried using the faders with cross fader in the middle. i tried ever setup i could think of.
geposted Sun 13 Mar 11 @ 10:21 pm
If you are using the External Mixer option in CONFIG -> Sound Setup, then please see https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html
geposted Mon 14 Mar 11 @ 6:18 am
@Support Staff,
He said he's recording "internally" not with an external mixer...........
Huey
Huey
geposted Mon 14 Mar 11 @ 7:46 am
thanks for the help. my laptop doesnt have a input on the soundcard, but my desktop has a input so ill try that.
thanks
keith
thanks
keith
geposted Tue 15 Mar 11 @ 11:14 pm
Im having a problem with recording also. Im using an external mixer and running a line from the mixer back into my laptop using the microphone portal but im not able to record live. I get just whats in the headphones. What can be done to record whats coming out of the mixer.
geposted Tue 29 Mar 11 @ 8:36 pm
@ lonzkat
You need to setup a loopback channel in advance SoundCard setup seperate from main output and headphone channels and use the control room output of your mixer to connect back into the laptop loopBack SoundCard channel you assigned in advance setup....
Good Luck,
Joey....
Good Luck,
Joey....
geposted Tue 29 Mar 11 @ 9:33 pm
djbigkeith wrote :
hey
thanks
keith
thanks
keith
What do you mean when you say "but when im cueing on the other deck it come thru on the recording".... please explain, is this the issue...
Anything you do with effects, tempo, fading to Deck 2, ect. will be recorded....
Joey...
geposted Tue 29 Mar 11 @ 9:47 pm
ok thanks for the help. i had to set my computer "line in" setting correct to get the recording correct. now that i have that issue solved i have another issue. i am using m-audio connective with external dennon mixers and cd decks. i checked the option in the recording settings of vdj to split the files everytime i move the crossfader but the files are not splitting it just creates 1 continuouse file. cna anyone tell me what i need to do to split the files.
thanks
keith
thanks
keith
geposted Tue 29 Mar 11 @ 11:36 pm
