So, I installed VDJ 7.0.3 and now I'm experiencing some technical difficulties.
I'm using the American Audio Radius 3000 in MIDI mode, and I'm also using the NI Audio 2Dj as my sound card. The problem comes in when I load up a track on deck one and it shows up on Virtual Dj as channel 2, and deck two shows up as channel 1. I thought it was just the USB cables plugged in incorrectly, so I swapped the ports, and still the same problem.
I stopped everything, restarted my lap top, and proceeded to load a song via deck one, and to my surprise, it loads up on channel two, and the funniest thing is when I load a new song via deck two, it also loads it up on channel two, swapped cables again and now deck one not responding. turned everything off again, restart all over again and OH SURPRISE!!!! now deck two is not responding at all.
Any ideas, or suggestions as to how to solve this MINOR ANNOYING issue?
geposted Sun 13 Mar 11 @ 3:36 am
Hi,
the way you describe this makes me wonder if both players are recognized by your computer. Can you check in the audio setup of Windows that both players are connected and visible as 2 different players/soundcards?
geposted Sun 13 Mar 11 @ 8:09 am
Please see your post in the General Forum -- and don't double post (even if someone suggests it) -- Mods will move the post to the appropriate forum if you ask.
Topic Locked
Topic Locked
geposted Sun 13 Mar 11 @ 10:35 am
