Every time i load a m4a (itunes codec music) it says error and doesnt play only when i play and mp3 its letting me play what should i do?
geposted Sun 13 Mar 11 @ 9:38 am
Sounds like you try to use DRM protected content from iTunes. You need to buy iTunes+ (unprotected) files instead.
Greets, Heiko
Greets, Heiko
geposted Sun 13 Mar 11 @ 10:33 am
Well all my songs were working just fine before and at least i dont think i changed any security things on it but i havent update my itunes to 10.1.2 yet could it be that? but thanks for the feedback
geposted Sun 13 Mar 11 @ 1:07 pm
What version of VirtualDJ are you using?
Older versions such as v5 Home Edition do not support the new codecs used by Apple for iTunes music.
NOTE: .m4p Apple DRM protected music cannot be played in any version of VirtualDJ.
geposted Sun 13 Mar 11 @ 1:46 pm
Im using version 6.1 for mac
geposted Sun 13 Mar 11 @ 4:19 pm
That version is old and out of date.
Please upgrade to the latest VirtualDJ v7.0.3: https://virtualdj.com/download/updates.html
geposted Sun 13 Mar 11 @ 4:53 pm
