I've read from previous threads that if you have the home version and then get LE with your controller you cannot have access to the free 20 day pro trial.
So if i uninstall my home version before running LE, will i be able to use the 20 day trial ?
(My Mixtrack pro is coming tomorrow)
geposted Sun 13 Mar 11 @ 3:03 pm
I know this is true if you already have the Pro version installed...
The way Atomix see it is that you don't need a trial if you already have the full version. It just doesn't tell you that when it happens
I shouldn't think it applies to the Home version though, because that's not the Pro version.
I may be wrong though - anyone from Atomix care to anwser?
geposted Sun 13 Mar 11 @ 3:14 pm
Cheers for the response.
I think it is for home version, as all 3 guys who were posting their problems all had downloaded home version a week before. And never had any other copy's.
If anyone from Atomix (or just generally in the know) could just confirm that if i uninstall home i will be ok to use the trial that would be great!
geposted Sun 13 Mar 11 @ 3:24 pm
