Forum: Old versions
Topic: Mixtrack pro, No sound comming from sound system
Hi , i just got my mixtrack pro, with vdj LE and i decided to try out the upgraded pro feautures so it all went good after my trial ended and i was back to vdj LE i tried to plug it in and when i played a song only music would come out of my headphones and no sound out of my speakers, i re-installed the program it still didn't work, help?
geposted Sun 13 Mar 11 @ 4:26 pm
bump
Most likely during the trial of VirtualDJ Pro you set configuration options that are not compatible with LE.
Go to CONFIG -> Info and click on the button to reset to factory settings.
Alternatively, download Home FREE https://virtualdj.com/download/free.html which will allow you to access advanced sound configurations and test Pro features for 10 minutes.
Use this to set your sound settings (CONFIG -> Sound Setup) as follows:
Inputs: None
Outputs: Headphones
Sound card: Numark
Click APPLY.
Close VirtualDJ Home FREE and then start VirtualDJ LE.
Also, make sure that you have the most recent VirtualDJ LE installed https://virtualdj.com/download/updates.html
