Setup: 2 V7's and a Hercules RMX going to an external mixer.
Is there a way to map a button to 'trade' which controller is controlling which deck? For example, If the V7's are originally controlling decks 1 and 2, and the RMX 3 and 4, is there a way to map a button so if I loaded a scratch sample onto deck 3, I could press a button and then the V7's controlled decks 3 and 2, and the RMX 1 and 4? (The left V7 'trades' decks with the left side of the RMX)
geposted Mon 14 Mar 11 @ 12:18 am
Check this thread it may help you, https://virtualdj.com/forums/135723/Hardware_Technical_Support/Advanced_Mapping_Verbs_Swap_Decks.html
Hope that helps
Huey
Hope that helps
Huey
geposted Mon 14 Mar 11 @ 12:23 am
that did help, thanks (:
geposted Mon 14 Mar 11 @ 12:43 am
You have already posted your issue to the above link.
Topic closed
geposted Mon 14 Mar 11 @ 6:32 am
