The problems haven't gone away.
My music sounds like absolute S**T when my VDJ lags in the middle of songs.
Can anyone help me? Why does my mates laptop not lag at all, with lower specs to mine, running the exact same setup?
geposted Sun 01 May 11 @ 5:06 pm
Post a video or screen shots of all your settings please.
Huey
Huey
geposted Sun 01 May 11 @ 5:28 pm
If you are receiving red spikes on DPC, then goto to your Hardware Manager and start disabling devices, one by one, and check DPC each time you disable a device. Once you spot which device is causing these red spikes, enable all the others and leave that disabled. If this device is essential for your system performance, then try to update drivers using the newest or even try older versions.
geposted Sun 01 May 11 @ 5:46 pm
Just did this and found 2 problems:
- NVIDIA GeForce GT330M
- Microsoft ACPI-Compliant Control Method Battery
What should I do about these two? With them both disabled, my DPC checker runs flat line low green. The NVIDIA is by far the worst, but I think I have the latest drivers?
Thanks
Thanks
geposted Mon 02 May 11 @ 3:54 pm
ACPI can be disabled but your main issue is that video card. Try to find and install the latest drivers from Nvidia website. Try also earlier versions if the latest is not running well for you.
Check the NVIDIA control panel on your computer and disable 3D performance.
geposted Mon 02 May 11 @ 10:17 pm
Disabled the ACPI and updated to latest NVIDIA drivers, problem seems to have improved somewhat.
Thanks for your help, I'll give it a try and see how it runs.
geposted Mon 02 May 11 @ 11:37 pm
Get the firmware update from Numark, that fixed similar problems on my unit.
geposted Mon 30 May 11 @ 2:02 am
