Hi I got my Mixtrack Pro today and i'm having real trouble wiring. I 'm not sure if i have all the wire i need.
I've got an RCA (red+white) plugged into my logitech speakers and a 3.5mm the other size which ?'m guessing would go into my laptop ?
The headphones obviously in the headphones input on the mixtrack.
But then i'm stumped ? do i need another rca to 3.5mm to come out of Mixtracks output's ? and where would this go ?
geposted Tue 15 Mar 11 @ 6:25 pm
USB the mixtrack to your laptop -all the sound is sent from the laptop to the mixtrack that way. RCA out from the mixtgrack to your speakers. headphones into the mixtrack You need an rca cable with both the red and white on each end - should have come with the mixtrack.
geposted Tue 15 Mar 11 @ 7:28 pm
Cheers for that mate.
I've figured i need to get a dual phono cable (red white, to red white), so that my outputs can go to the inputs on my sub, cheers :).
geposted Tue 15 Mar 11 @ 7:36 pm
Hey i have a problem too! I tried the Virtual DJ LE with my mixtrack pro and now that i have the Virtual DJ Pro, I try to connect the Mixtrack pro with VDJpro and, in the Config, the mixer doens't even appear. What can i do?
geposted Sun 01 May 11 @ 1:29 pm
