Maybe this is a question for the teamers, but does anyone know if the Novation Dicer is mappable in VDJ?
http://www.novationmusic.com/products/digital_dj/dicer/Compatible+with+Traktor+Scratch+PRO/
I\'d like to play around with these as they would be pretty awesome for loops, effects and even samples.
Thanx for any and all input.
AC
AC
geposted Tue 15 Mar 11 @ 9:24 pm
geposted Tue 15 Mar 11 @ 9:34 pm
Very nice! Thank you sir.
geposted Tue 15 Mar 11 @ 9:59 pm
I bought a set of these today and mapped them to my requirements. 10 Sample buttons, 5 Hot Cues, 5 "go to" cue points, and a pile of looping features. I remapped them because my VCI-100 has alot of the controls that were pre-mapped to the dicer (ie. pitch bend and sampler volume).
I gotta tell the community that these integrate easy with VDJ, are easy to re-map if you don't like the default mapping, they feel good and are pretty durable little units (so far). For the cost, I have to say they are probably the coolest and most functional midi device that I've seen so far.
If anybody is looking at these and has any questions, don't be afraid to hit me up.
Happy mixin.
AC
Happy mixin.
AC
geposted Tue 29 Mar 11 @ 9:27 pm
Hello!
I got a denon mc6000 with 2 turntable time code vinyl and a dicer.
I only use a denon or dicer but not the 2.
With denon and dicer connect, virtual is "freeze" and not work.
What can i do?
Thanks!!!
What can i do?
Thanks!!!
geposted Fri 28 Jun 13 @ 10:03 pm
Hello,
please register your Professional Full version in your profile and check for updates.
This Thread is over 2 years old. So if you still have problems after the update please create a new Thread in the forum for it.
Greets, Heiko
Greets, Heiko
geposted Sat 29 Jun 13 @ 12:09 am
