I am using Pro 7.0. My jog wheel and everything on the "CD Player" sides on the mixdeck are working. But nothing on the mixer park, no LOW, MID, HI eq, no crossfade, no channel volume. Nothing. When i go into "mapping" and "key learn" then tweak something on the mixe, it doesnt show anything. Please help.
geposted Wed 16 Mar 11 @ 5:28 am
That's normal. Mixdeck has an analogue mixer. It's not a midi mixer. So you cant map it, and you cant see those faders and knobs moving on the screen. It's like using a separate external analogue mixer.
geposted Wed 16 Mar 11 @ 11:31 am
my mixer is same, i wish it had USB.
geposted Fri 18 Mar 11 @ 5:26 am
i found out that problem wen i was trying to record my mixin and after 5 hrs of mixing i thought, why is my mixing so terrible
geposted Fri 18 Mar 11 @ 5:27 am
Please see https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html for details on how to record when using an external or non-MIDI mixer.
geposted Fri 18 Mar 11 @ 7:11 am
do i plug it in my mic, or shall i get a external sound card w/ audio in on it.
geposted Mon 21 Mar 11 @ 1:31 am
External card FTW.
geposted Mon 21 Mar 11 @ 7:46 am
thanks
geposted Tue 22 Mar 11 @ 2:13 am
