HELP!!
OK I'm going nuts!
I just want to lock the pitch on all decks and keep them that way unless I move the pitch fader, press the pitch bend buttons, or hit the sync button.
I load deck A and deck B...Press play on B...at the end of the song (while deck B is still playing) I press play on deck A and the pitch trys to match deck B every time
I have tried the fader lock function per the manual and tried every pitch funtion in the config menu!! I just want to lock the pitch.
Has anybody ran into this?
OK I'm going nuts!
geposted Wed 16 Mar 11 @ 10:57 pm
You must have smart play enabled on one of the decks. Load the default skin and look for a highlighted padlock then disable it.
This happened once to me during a gig and confused the hell out of me!
Keith
Keith
geposted Thu 17 Mar 11 @ 5:40 am
I did that Keith...Still having the same issue. It only happens on deck 1/A very strange.
Last night I just used decks 2/B and 3/C and everything was fine. I will have more time tonight to try to figure this out, Karaoke night usualy has a slow start.
geposted Fri 18 Mar 11 @ 4:44 pm
Hmmm, you've got me stumped on that one. Have you tried resetting the mapping to default to see if that sorts it?
Keith
Keith
geposted Fri 18 Mar 11 @ 5:52 pm
After changing mappers and skins and adjusting every pitch setting there is.... I think this seems to be user error! I pressed shift and sync/master on deck 1/A at the same time and my problem went away, at least for now...this is pre gig so we will see how it goes the rest of the night.
I guess I must have pressed shift and sync/master to cause this to begin with.
Always hate to be the guy with the brain fart posting questions on the forum.
Thanks for your help Keith!
geposted Fri 18 Mar 11 @ 7:25 pm
Shift + Sync/Master is the Masterdeck action. By clicking on a masterdeck actrion on a deck it will force that deck to be permanent masterdeck until you change that manually again, and all the other decks will sync to that deck. (manual assignment)
By clicking that button once again masterdeck will return to automatic assignment. When you mix with 4 decks you should use a skin with masterdeck feature in order to view and check.
geposted Fri 18 Mar 11 @ 7:43 pm
Ahhhh,
Thanks Bob, I'll remember that one!
Keith
Keith
geposted Sat 19 Mar 11 @ 2:40 am
