I'm fairly new to mixing and so I'm trying to learn to beatmatch without looking at the display on the computer screen but doing it by feel alone without using the sync button. I can get it very close, but does it matter if one track is at 137.04 and the other is at 137.12? The increments don't get exact? I try to adjust it to match it up (this time by looking), but if I try to slow down the one at 137.12 by a notch, it might go down to 136.98 or something... skipping over 137.04. Is this a big concern? Does more advanced hardware give closer increments with VDJ?
Thanks!
Thanks!
geposted Fri 18 Mar 11 @ 11:33 am
you can try and change pitch range in setting to 8 or 10% to get more accurate pitch slider
geposted Fri 18 Mar 11 @ 3:05 pm
it wuold be very hard to get two tracks to match up bpms within two decimal places... use the jog wheel (the outer silver part if you are in scratch mode) to nudge the track forwards or backward to catch up with the playing track... OR use the pitch bend buttons to momentarily speed up or slow down the track you are cueing
geposted Sat 07 Jan 12 @ 2:47 pm
