Whats up guys, im getting ready to oder my first turn table and ive been thinking about different things. If i get the Numark Mixtrack Pro from like guitar center, will it still play on VDJ Home edition? Also will it play threw my laptop?
geposted Fri 18 Mar 11 @ 11:50 am
Well the Home version is basically meant to be used a trial, you can use most of the pro features for only 10 minutes then the system resets. As far as the Mixtrack goes get the pro and it comes with VDJ LE I believe and with that you can enter the serial number for a discount off of VDJ 7 PRO. Now as far as the sound and where it comes from I can't help you there cause I've never messed with one before.
Hope that helps
Huey
Hope that helps
Huey
geposted Fri 18 Mar 11 @ 2:13 pm
