Hello, I wonder, is there any easy way to refresh data in the database for renamed file?
Example:
I have file named 50Cent - Have a party.flv
I have all the setup for this file (BPM, mixpoints...manually, lot of work)
I rename it to G-Unit - Have a party.flv
Now, how to link the data for multiple songs like this (according to name similarity, filesize, IDtags or whatever?)
Thanks
Example:
Thanks
geposted Sat 19 Mar 11 @ 12:31 pm
Unless you have cleaned the DB it will still be there.
Rename the file to the previous name, put it in the previous file location and you will be able to load it in VDJ again.
Then use the file info box in VDJ to rename the file and this will keep all the DB info intact.
Keith
Keith
geposted Sat 19 Mar 11 @ 1:08 pm
Thanks...
not automatic as I would like (there are many songs I changed), but at least solves the problem;-)
geposted Sun 20 Mar 11 @ 8:20 pm
