Can VDJ use KMA karaoke files?
I have Video Hoster for karaoke but want to use VDJ. Hoster uses KMA files. I want to use those KMA files with VDJ. Can I?
geposted Sat 19 Mar 11 @ 3:20 pm
Sorry City. Karaoke file supported are MP3+G, WAV+G, WMA+G, OGG+G, and .ZIP files only. They would have to be converted to one of those formats to use them in VDJ (which may or may not be a pain in the ass). I'm not familiar with converting that file extension, but maybe one of the others will chime in.
Hope that helps bro,
AC
AC
geposted Sat 19 Mar 11 @ 3:45 pm
Hey City,
if you go to browser in config it list the extensions for the files supported.
geposted Sat 19 Mar 11 @ 5:57 pm
Hey djcity,
You use the Hoster program, well the only way you'll get those files to work is to use their converter program to convert back to Zip's...
I also had the same problem, the file folder for those files are useless, ....cause you can only see the disk numbers which doesn't give you any title or artist info like you would find in any media file program made today....
Joey....
Joey....
geposted Sat 19 Mar 11 @ 6:11 pm
