Whats up guys, Ill start the song on VDJ and itll be semi-low, about 20 seconds threw the song itll get really loud. Any reason for this? Its basiclly changing its own volume.
geposted Sun 20 Mar 11 @ 9:28 am
Relax bro you just posted this give people time to wake up, lol! While usually it's the other way around, starts out loud then gets quite. Have you scanned all your tracks? Does this happen with every track or just a few?
Huey
Huey
geposted Sun 20 Mar 11 @ 9:40 am
Sorry for the double post the reason it was posted twice was because i forgot to add "seconds" lol. It does it both ways around, itll start loud and then go lower, once its lower it comes back up to loud again. Its annoying, and its also on every track.
geposted Sun 20 Mar 11 @ 9:42 am
Ok have you scanned the tracks first? Highlite a track then hold "CTRL" and hit "A", this should highlite all the tracks. Now right click on a track and then hover over "BPM' and click on "RE-ANALYZE"
Try that and let us know what happens now
Huey
Huey
geposted Sun 20 Mar 11 @ 9:52 am
Says Scan For BPM, Is that correct?
geposted Sun 20 Mar 11 @ 10:02 am
Yeah, make sure you scan all your tracks before you play them.
Huey
Huey
geposted Sun 20 Mar 11 @ 10:04 am
I scanned one of my playlists, It just Re-anazlyzed the BMPS, I guess. Nothing came up on the screen or anything except the "Scan Track" Window. Also, What is the purpose of scanning tracks before playing?
geposted Sun 20 Mar 11 @ 10:10 am
Always scan your tracks for BPM's as soon as you can. You will then know in advance what the BPM's will be plus VDJ will have analised the track for gain, automix, etc. Before you play it for the first time.
Create a filter along the lines of days since firstseen <5 and isscanned = 0. That way you will always be able to speed up the scanning process after adding new tracks.
Huey
Huey
geposted Sun 20 Mar 11 @ 10:15 am
Alright, I appreciate all your help, and also could these mean something, Im playing threw my dvd player using mp3 link. Could this cause it?
geposted Sun 20 Mar 11 @ 10:23 am
It is likely your DVD player causing the volume problems. This is a common occurrence especially with burned discs.
Regards,
AC
Regards,
AC
geposted Sun 20 Mar 11 @ 3:07 pm
