Topic: Numark Mixtrack Pro Question
Whats up my people, I currently live in Atl, GA, and this guy has a Numark Mixtrack Pro for sell for $100, and he said he will sell it to me. Well i dont have VDJ Pro, and im posted about this before but i never got an exact answer. Will the mixtrack pro still work with VDJ Home until i buy pro?
geposted Sun 20 Mar 11 @ 2:37 pm
Only for the first 10 minutes of software use. Then it reverts to mouse and keyboard control.
Regards,
AC
I appreciate it, so the pro version is well worth it?
Also what if i had VDJ LE? Would i be able to use it?
Like I said in yOur other post about the same thing if you buy a Mixtrack PRO (the one with the soundcard) it should come with VDJ LE and you won't need to use the home version. Plus you'll get a nice discount on the pro version. So my advice is if it ain't brand new don't waste your money cause the serial number that comes with it is worth alot and you never know if he's already registered it (unless you know the cat personally).
Huey
If the seller has already registered the VirtualDJ LE serial number, then you will not be able to register it yourself.
VirtualDJ licenses cannot be sold, given or transferred to another user. Doing so is a violation of the End User License Agreement: https://virtualdj.com/atomixproductions/disclaimer.html
However, if he has not already used the upgrade discount, you may be able to still use it to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/
Otherwise, you will only be able to use the original version from the CD with no updates and would need to purchase the full VirtualDJ Professional if you wish to run a newer/less limited version of the software.
As above, unless you can be absolutely sure that it's not been registered, it's best to purchase your own console brand new.
i just bought mine and i can tell you it's worth it. especially when you're doing video mixing.
Pro is well worth it.....& I love my mixtrack pro
