Hi. I have a numark mix deck and a macBook. I installed virtual dj and in works fine with a Pc but i'm having problems with the MacBook. Does it needs a different set up? If any of you guys have the same equiment as me, please let me know what i need to do. Thank you all.
geposted Mon 21 Mar 11 @ 9:44 pm
Hi, I hope you've had luck since your last post but if not make sure you have the following:
1. the latest Numark drivers
2. the latest VDJ
other than that I do absolutely nothing diffferent
2. the latest VDJ
geposted Fri 15 Apr 11 @ 8:33 am
2. the latest VDJ
I already try with the newest version and not luck
2. the latest VDJ
geposted Tue 19 Apr 11 @ 5:39 pm
dude im having the same problem on my mac. it runs just fine off my netbook, but the mack just stopped recognizing it... it's not a virtual dj problem, its the mac
geposted Sat 01 Oct 11 @ 4:42 am
I m having the same problem too. it worked fine with the pc but now i switched to mac book nothing. I downloaded all the latest updates for VDJ and numark nothing happened. VDJ plays off the lap top but doesn't recognized numark mixdeck even thou, it says its connected... I wanted to switch from the trial version of VDJ but now a little skeptical that i might waste my money if its don't work. any body got an answer cause it seems that a lot of us are having this issue.
geposted Sun 06 Nov 11 @ 5:00 pm
After installing the latest drivers, connect your Mixdeck with a USB cable - turn it on - Go to Mac Applications/Utilities/Audio-Midi and make sure your Numark Mixdeck appears on the list aside from built-in input/output. If it appears there, set it as your input and output device.
Then do the VDJ Sound & Mapper configurations.
Hope this would help... Goodluck!
*Note* Don't expect the Mixdeck mixer part to react as midi-controller... it is actually an analogue mixer.
geposted Mon 07 Nov 11 @ 1:37 pm
Done all that with my brand new Macbook pro and its not listed!!!....so now what?!! Must be other new Macbook pro people with same problem??
Thanks
Thanks
geposted Wed 09 Nov 11 @ 5:36 am
Please check if you really have started the latest VDJ version 7.0.5.
VDJ Config - Info
Please try to do a complete VDJ deinstall .
https://virtualdj.com/wiki/Mac%20Clean%20Re-install.html
After that set it up like that:
https://virtualdj.com/wiki/MixTrack%20Pro.html
VDJ Config - Info
geposted Wed 09 Nov 11 @ 6:26 am
When i say its not listed it's my mixdeck that is not listed as an audio device in my macbooks sound devices are per the post above and therefore not surprisingly VDJ, or Traktor for the matter cant find it!!!
geposted Wed 09 Nov 11 @ 7:51 am
THIS SHOULD SOLVE IT
With OSX 10.6 and higher this will help with get it recognized. I hope its not repetitive for you but it has helped others:
1. Using the “Numark Driver Remover” remove Driver version 2.0.2.
2. Restart*
3. Download driver 1.6.9 and install.
4. Restart
5. Remove driver 1.6.9 using the “Numark Driver Remover”
6. Restart
7. Install driver 2.0.2
8. Restart
You will be forced to restart after the installation of new drivers.
2. Restart*
4. Restart
6. Restart
8. Restart
geposted Fri 09 Dec 11 @ 9:56 pm
DId any of you that have the problems got them fix?? I cannot Find the way to fix this.
geposted Sat 12 May 12 @ 11:32 pm
I was having the same problem using my mixdeck with a mac, i figure out it was Lion was causing the problem that wasnt recognizing the mixdeck so what i did i downgrade my lion to snow leopard and it did work !!!!
geposted Sat 19 May 12 @ 7:04 pm
hey raulrosa01, i got it fixed without having to downgrade. i had to reinstall many times to have it work. The only problem now is when i change the config for broadcasting>>it freezes after changing the advanced options, it doesn't let me. I follow and read all the forums, if anyone help me to fix this problem will be greatly appreciate
henry_v
geposted Tue 22 May 12 @ 3:27 pm
Has anyone found a more practicle solution to this?
geposted Wed 29 Aug 12 @ 5:09 pm
