Forum: VirtualDJ Skins
Topic: ok dumb question here..........
When you guys say the "skin should match my screen resolution" what exactly do you mean and how do I find out what my resolution is?? Is it where I go to setup my extended desktop?? If so my screen is set to as high as it'll go and I believe its something like 1600 by something. It's only a 15 inch laptop so I'm gonna assume that I have something wrong here? And just let me say that I don't see a difference in CPU usage when the skin is minimized or maximized.
And can you put it in laymen terms please, Thanks for the time
Huey
geposted Tue 22 Mar 11 @ 1:30 am
Yeah, Screen Res is accessed from desktop just right click on your desktop and choose properties and then settings. Usually just a sliding scale always best to choose highest unless you have bad eye sight.
Thanks Charlie, ok so I was right. Now the next question, do I resize the skin to match that number below the slider on the screen?
Thanks for the time and info
Huey
In a word, .. yes !
In a word, Thanks! Lol!! Ok ill try it pt and see what happens.
Thanks for the time fellas.
Huey
