Is it possible to make skins for multiple screeens?
I have never made any skins, but I would like a skin for 2 separete screens. One with the players, and one with the katalogs/music.
The reason is, that I want to use 2 small screens with lower resolution(1024*768).
Is that possible?
Is that possible?
geposted Tue 22 Mar 11 @ 10:31 am
Yes it is possible. The skin must have a total resolution 2048X768.
I have made a couple of such skins, for touchsceens mainly. But the available resolutions might not fit to your screens.
https://virtualdj.com/addons/12627/VirtualTouch_Double.html
https://virtualdj.com/addons/9018/Double_Touchscreen.html
They are both at 2560X1024. If you use the Resizer Tool in Simple Resize Mode the result will be.. 2048X820. So your graphics will be minimum squeezed.
Which skin do you currently use ?
geposted Tue 22 Mar 11 @ 10:51 am
Wow, thanks.
I use only one monitor at the moment, and is trying out different skins.
My plan is to buy two small screens(touchscreens i think) and build them into my case.
I´m going to try this skin. Thank you.
geposted Tue 22 Mar 11 @ 12:26 pm
