So i've been using the mixtrack pro fine for ages and it was all working well with virtual dj 7. I was messing about with the settings trying to get my microphone to work and now in 2 of the 3 usb ports on my computer it doesn't play any sound out of.
It works fine on the third usb - one that it hasn't been used on before - but on the two that it has been used on, no sound output from both the headphones/monitors are transmitted.
On all 3 usb connections i have this setup
http://img19.imageshack.us/img19/4749/numark223.jpg
but like I say 2/3 usb ports it doesn't transmit sound but does respond to the movement of a knob/crossfader etc. Is it to do with the USB Bus not working correctly? If so how do i go about finiding them and re-installing them on windows vista.
Please help.
Edit: from what i've read it seems that the mixtrack pro doesn't have drivers. So how do I go about resetting the usb ports so that it reocgnises there is a new device attached?
Please help.
geposted Tue 22 Mar 11 @ 10:48 am
Bump for help please.
geposted Thu 24 Mar 11 @ 10:31 am
With it plugged into a failing port, try to remove the newmark sound card from the device manager. Not disable, but remove. Then unplug the usb cable, wait a few min, and reinsert. See if windows "finds" the sound card again.
geposted Tue 05 Apr 11 @ 12:48 am
