First, describe to you what and how. So with 2 sound cards. One Realtek HD integrated, and the other Creative Sound Blaster Audigy installed. So the options in such VDJ version 6.0.6 Outputs Headphones set, in the Sound Card 2 Cards and the first as the selected audygi Sb and the other Realtek HD Audio output. Of course, the speakers connected creativa Sb 5.1 and the Sennheiser HD202 realterk. The problem occurs when you start recording using the Record Audio Config set the Master + Mic Sb and choose the card attaches to a microphone. After a few minutes there is a Crash Guard. Even when the microphone is disconnected and are further retained the same settings or Master + Mic. But when I turned on the recording and the act itself does not occur Crash Master gave advice to anyone solve this problem?
Also reports that almost every version of VDJ has been checked, each is smao. Drivers for sound card and reinstal system has also been made.
geposted Tue 22 Mar 11 @ 11:04 am
VirtualDJ v6.0.6 is an old and out of date version of the software. We are now on v7.0.3 and there have been many changes and improvements to the software since this old version.
Please upgrade to the latest VirtualDJ v7.0.3 https://virtualdj.com/download/updates.html
If you still get the crash in v7.0.3, then please post your crash guard report which you can find in My Documents\VirtualDJ - This contains debugging information that may allow the dev team to determine the cause of the problem and fix it if necessary.
Please also ensure that you have the latest drivers installed for your sound cards.
geposted Tue 22 Mar 11 @ 12:16 pm
Crash ID=01d94293 (date=1103191149, version=7.0.2 Pro, build=347, thread=Record, dump=dc04cd00, excode=c0000005 (0,a7df3200))
Crash ID=03814293 (date=1103210855, version=7.0.2 Pro, build=347, thread=Record, dump=dc04cd00, excode=c0000005 (0,a9873200))
Crash ID=032842b1 (date=1103210858, version=7.0.2 Pro, build=347, thread=Record, dump=dc04cd00, excode=c0000005 (0,a92e3200))
geposted Tue 22 Mar 11 @ 12:40 pm
I want to add that when the headphones are disconnected from the sound card and speakers will be the same crash does not occur.
geposted Tue 22 Mar 11 @ 4:23 pm
v7.0.2 is not the latest version.
Please register on this page:
https://virtualdj.com/users/edit.html
Then download v7.0.3 Pro from:
If the problem persists, please post the crash logs for v7.0.3 below.
geposted Wed 23 Mar 11 @ 6:20 am
Crash ID=01aa4293 (date=1103182132, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a7b03200))
Crash ID=034e4293 (date=1103191033, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a9543200))
Crash ID=032e4293 (date=1103191055, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a9343200))
Crash ID=01aa4293 (date=1103191112, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a7b03200))
Crash ID=01aa4293 (date=1103191303, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a7b03200))
Crash ID=037e4293 (date=1103211208, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a9843200))
Crash ID=01ad46a9 (date=1103212156, version=6.0.6 Pro, build=605, thread=Record, dump=0fbe0c31, excode=c0000005 (0,1fef5838))
Crash ID=033d4293 (date=1103221628, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a9433200))
Crash ID=04ca4293 (date=1103221636, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,aad03200))
Crash ID=05234293 (date=1103221645, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,ab293200))
Crash ID=066b4293 (date=1103221725, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,ac713200))
Crash ID=03af4293 (date=1103221731, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a9b53200))
Crash ID=03b24293 (date=1103221856, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,a9b83200))
Crash ID=067242b1 (date=1103231426, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,ac783200))
Crash ID=06774293 (date=1103231427, version=6.0.6 Pro, build=605, thread=Record, dump=dc04cd00, excode=c0000005 (0,ac7d3200))
This is a crash with version 6.0.6 pro. I've mentioned above, that the version of virtual dj karzdej pops the crash and began to link it to the shoutcast server. Crash occurs when the options are selected Virtual Dj 2 cards. When a crash does not occur. This may be due to errors in the system or something? Previously there has not been so.
geposted Wed 23 Mar 11 @ 8:32 am
As previously stated, please enter your pro serial on this site and download version 7.0.3
If you are unregistered and using an illegally downloaded version that may explain why the software is crashing.
Keith
Keith
geposted Wed 23 Mar 11 @ 10:12 am
Please update to the latest version (7.03) https://virtualdj.com/download/free.html
Dev Team is only debugging the current version, so it's pointless to post crash reports of previous versions.
In case you update to latest version, please open a new thread posting your issues.
Topic Locked
geposted Wed 23 Mar 11 @ 11:48 am
