Hello my fellow VDJ Peeps!
I haven’t posted anything in a while, hope everyone is well.
OK question regarding the cross fade options. Sometimes what I like to do is move the curser to the center. I’ll move it while it is on the “cut” setting so that it does not change the image of the video I’m currently playing. Now keep in mind, I’m talking about playing live, not using auto smart. Anyway, it used to be that I could do this (move the curser to the center while on cut) and then if I wanted to use a different cross fade option, such as “fade”, “light fall”, “grid”, etc … I could make the change while video #1 is playing and it would not change the image. It would only change when I hit the space bar to release the next video. However, sometimes it seems to go back and forth. Currently this is not working for me. If I change the cross fade options after I’ve moved it to the center (from “cut” to any other option) it will change it to the new setting before I'm ready for it to be changed. It used to not do it until only after hit the space bar. Is there something I’m missing? How can I get it to do that again? It did it for the longest time and now it’s not.
I hope I made sense.
geposted Tue 22 Mar 11 @ 12:12 pm
Anyone?
geposted Wed 23 Mar 11 @ 10:01 am
