When i try and open my software (VDJ 7) it says that the software is set to a resolution to higher than what is supported by my monitor. The software loads and runs fine, but appears to be running off my window. I can right click on the taskbar tab and chose to "move" the software window, but that doesn't get ahold of it either.
Is there a way i can change the resolution of the window with hotkeys or anything like that?
Any help is greatly appreciated!
geposted Tue 22 Mar 11 @ 9:23 pm
The default VirtualDJ skins require a minimum screen resolution of 1024x768
Please ensure that your screen is set to this resolution or higher.
Custom skins for smaller resolutions such as NetBooks can be downloaded from https://virtualdj.com/addons/skins.html, but these are only available to registered licensed users who have purchased the software: https://virtualdj.com/products/comparison.html
geposted Wed 23 Mar 11 @ 7:04 am
