What is the best way to use 4 decks on VDJ with 2 CDJ 800's and time code and be able to switch which deck the time code controls? right now I have to use the mouse to select the current deck playing, turn off time code, then select the other deck and turn on time code? is thre a simple key combination to switch between 2 decks on each side with time code??
Thanks!
Thanks!
geposted Tue 22 Mar 11 @ 11:31 pm
