please, vdj7 is full of bugs, my sound is still crackling, other ppl have different problem, MAC has problems.
ever since i got this update iv had problems with my sound which i never had b4 in VDJ 6.
is ther anyways of getting back VDJ 6, please send me the link. i really NEED it by this SATURDAY
geposted Wed 23 Mar 11 @ 11:27 am
I think that the majority of VDJ Users are enjoying a stable version 7. I don't see too many crash reports either. I'm not aware of your sound issues, probably have to do with your personal setup, drivers etc. Sound pops and cracks usually are related to your hardware setup and some faulty drivers, rather the software itself.
In any case, you can raise a Ticket https://virtualdj.com/contact/ and ask from Team to add to your Download Center a link to previous version.
geposted Wed 23 Mar 11 @ 11:42 am
i never had that problem b4 when i had VDJ 6. since VDJ 7i cant get it fixed, i found that link just minnutes ago and came across this.
I am getting pops, crackles, and clicks in my sound.
Your performance settings may be set to a value greater than your hardware is able to utilize. Because you are most likely using an ASIO sound card - please set your performance settings under CONFIG -> Performance tab to the following:
Slide the fader all the way to the left, then on position to the right of Fastest.
Change the Latency drop down to AUTO
Uncheck SafeMode and Overclock.
Leave all other settings unchanged.
If the problem still persists, then go to CONFIG -> Sound Setup again and click on the ASIO Config button. This will display your sound card's ASIO control panel. Increase the buffer size and then restart VirtualDJ. Repeat this until you find the optimal value for your computer.
Also, for a USB sound card make sure that you always plug it into the same USB port each time to avoid the "Error in DirectX" message.
this mite help me and others and thanks djDAD
geposted Wed 23 Mar 11 @ 11:56 am
Please see https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html for a list of common causes of performance issues and their solutions.
geposted Wed 23 Mar 11 @ 1:48 pm
ill have a look at it when i get home, ill test my system again and ill post a vid up, my lappy sits on a stanton urbanstand and its pretty venti (ventilation) for it
geposted Thu 24 Mar 11 @ 1:18 am
ok, just played for about 31 mins and no crackling, i reckon the setting wer wrong and now they r rite. im gonna try again tomoro and SAT.
thanks guys
thanks guys
geposted Thu 24 Mar 11 @ 11:10 am
vdj should have a page for all pro licensed users with links to past versions of vdj. another dj software has done this for ppl who have had better luck with previous versions of the software.
geposted Thu 24 Mar 11 @ 12:15 pm
Older versions can be made available on request by simply asking in support: https://virtualdj.com/contact/
(Obviously we can only make versions that your license entitles you to available.)
NOTE: The majority of users have no problems with the latest versions of the software. We always recommend using the latest version of the software. Most problems that users do have are usually system and/or configuration issues and can normally be resolved.
geposted Thu 24 Mar 11 @ 1:28 pm
^ good call
geposted Thu 24 Mar 11 @ 2:33 pm
LIKE (just like facebook "LIKE")
geposted Thu 24 Mar 11 @ 3:58 pm
iv always seen that service support but never used it until the other day, and wen djDAD put it up as well for me at the same time. what good timing was that.
i think every1 should use that, that have problems coz it sorted me out
geposted Thu 24 Mar 11 @ 4:20 pm
While I've only rarely had to use them, every time I download a new version of VDJ, I save the installation file for that version in its' own folder as a backup. If I ever need to "roll back", I have what I need to do that, even at an event, if it came to it.
geposted Tue 29 Mar 11 @ 2:33 pm
i have VDJ6 version 6.0 but without the updates, i would delete the updates after installation.. Doh!!!!
but now i just mixed again for a good few hrs with some new tunes i just downloaded and all seems very fine to me.
from now on ill b doing the same, backing up all my updates.
got a gig this SAT nite so its all good.
geposted Wed 30 Mar 11 @ 6:12 am
