I'am using the 4 deck skin, I wanted to know if there was a way to assign to a button to switch between decks. I'am not talking about left to right deck switching. What I mean is if there is a way to switch between decks on just one side and vice versa. Like switching between deck 1 and 3 or switching between deck 2 and 4. I've been looking in the key mappers but cannot find it and i tried using the action learn to. I'am using traktor total control and wanted to map that key to a button so i wont have to move the mouse over to the screen to select from deck 1-3 and deck 2-4. Basically like the switching from left deck to right deck but instead of that switching from top deck to bottom deck in the 4 deck skin. Hopefully you understood what I was trying to say lol
geposted Thu 24 Mar 11 @ 3:29 pm
Yes of course it's possible. Take a look at this thread https://virtualdj.com/forums/135723/Hardware_Technical_Support/Advanced_Mapping_Verbs_Swap_Decks.html
You will find several solutions.
geposted Thu 24 Mar 11 @ 4:19 pm
