I am having an issue with skins not work. I keep getting a massage to I need to download VDJ, but I am using the program. Is it cause I am trying to use old skins.
geposted Fri 25 Mar 11 @ 7:43 am
Do those skins appear in the skin tab (config menu of VirtualDJ)? Ver 7.03? Do you have trouble installing new or old plugins from the Plugin Download Page?
See here..
https://virtualdj.com/forums/144671/General_Discussion/Skins__Effects__etc__saying_VirtualDJ_is_not_installed.html
You may use old skins as well with no issue.
See here..
geposted Fri 25 Mar 11 @ 12:33 pm
o after i downlaod them. i run them and then I get an error message. VDJ needs to be installed
geposted Sun 27 Mar 11 @ 8:31 am
then the above link will give you a solution to your issue.
geposted Sun 27 Mar 11 @ 9:53 am
