Hi
I have just got the hercules rmx & hooked it up with Virtual DJ
I can play my MP3's with the settings for input on line in
I can also put my Technics 1210 into the phone input, change the source & play this however I need to change the input settings to timecode and when I do this on the other channel the mp3 doesn't play
Basically I would like to be able to mix my vinyls and mp3's at the same time but can't get it to work
Help please! One of the reasons I got the hercules rmx was so I could do this as I have 1000's of vinyls and haven't got the time to convert them all to mp3's
geposted Fri 25 Mar 11 @ 1:42 pm
^ u will need to upgrade to the pro version to use the tcv feature. once you do that, you can click on the "source" button for whichever deck u wanna run vinyl on and it will stream in and out the phono signal coming out of that deck.
in this way you can run actual vinyl on one deck and mp3 on the other.
geposted Sun 27 Mar 11 @ 12:41 pm
Thanks for the reply
I should have been clearer in the original post - I am actually now running the Pro7 version (when I bought the hercules rmx second hand off ebay the pro version came with it)
Can you explain what you meant by TCV?
I can run the source as vinyl but I need to run deck A as the phono input & mix in Mp3 from deck B
CHeers
CHeers
geposted Sat 02 Apr 11 @ 3:40 am
rmx should have came with the LE version, not the pro. you would have had to buy it separately.
geposted Sat 02 Apr 11 @ 3:51 am
I know that the rmx comes with LE version
I bought the rmx on ebay & the seller included his full version of VDJ pro - I paid extra for that
Can you explain what you meant before?
Cheers
Cheers
geposted Sat 02 Apr 11 @ 8:30 am
I've just realised that by TCV you mean time-coded vinyl
I have already seen that in the Input in settings you can change it to this - however if I do the vinyl works on one deck but the MP3 doesn't on the other
Similarly if you change the input to Line ins then the mp3's work but even when change the source on the hercules the vinyl doesn't
What am I doing wrong?
geposted Sat 02 Apr 11 @ 8:35 am
has to be in phono since your doing turntables, you use line for cdjs
geposted Sat 02 Apr 11 @ 8:44 am
I'm not talking about the back of the hercules - I know it has to be phono - I was talking about the input settings in virtual DJ
What i'm saying is that when I press the source button to change deck A to the vinyl it does not work how do I get it to work?
geposted Tue 05 Apr 11 @ 12:21 pm
it should work, post a video if you can
geposted Tue 05 Apr 11 @ 12:24 pm
dave im having the same problem.. i have virtual dj pro 7 which i bought today. when i press the source button on the rmx so i can use my turntable nothing happens. i had no problem using the source button and mixing vinyl using the virtual dj LE edition. can someone help me out?
geposted Tue 24 May 11 @ 12:07 am
@Mattos000
Did you configure VDJ to work with your turntables ?
If you are using timecodes, the audio configuration should be something like:
- Input : Timecodes
- Output(s): Headphone >Master Chan1/2 / headphone Chan3/4
-Soundcard: DJ Console Rmx
For standard vinyls (or other external sources) the audio configuration should be
- Input : Line Ins
- Input : Timecodes
- Input : Line Ins
geposted Tue 24 May 11 @ 2:53 pm
hey phatso thanks for your help ill give it a go when i finish work and let you know cause right now i have it on input: none
geposted Tue 24 May 11 @ 5:18 pm
Here is a video walk through.-----> http://www.youtube.com/watch?v=CSMwQD-3euY
Includes cable connections + explanation, Switch settings on Hercules RMX, and Settings on VDJ Pro.
Hope it helps the reading impaired
BTW DJ Phatso did a good brief writeup/check list. WTG!
We should make that part of the manual and if they have problems we just reply "RTFM!!!!"
Just kidding... we will always help out our friends, peers and fellow colleagues.
Sincerely,
DJ Esco
Sincerely,
DJ Esco
geposted Mon 24 Oct 11 @ 5:19 pm
