Topic: DENON DN-MC6000 help on specs please
I'm a little confused on one of the specs of this unit. It says:
"Pitch/Fader/Volume Lock function - holds the last known Audio value and position until the NULL point is reached again"
What exactly does that mean?
Thanks!
JM
geposted Sat 26 Mar 11 @ 11:07 am
It's a safety feature - When you toggle between decks (E.g: A -> C), if you then move the pitch slider and then toggle back to deck A again, the pitch slider will no-longer be in the correct position.
The controller will ignore all further movements of the pitch slider until you move it back to the correct position again, preventing a sudden jump in pitch that would occur otherwise.
This feature is common to most MIDI controllers in VirtualDJ. Please see https://virtualdj.com/homepage/jpboggis/blogs/4161/Pitch_slider_on_external_MIDI_controller_does_not_always_work.html
