is it possible to have my Numark DXMPRO Mixer to work with my 2 Numark V7 on VDJ? My V7 works but only one of them as for the mixer it's not even showing upand I have to use the mouse to crossfade... I'm not sure if it's possible but I wish it would be as I dislike the Itch program compare to my VDJ. Maybe I made a mistake buying these...Thanks in advance for all of your help...
Ron. aka DJRB
Ron. aka DJRB
geposted Sat 26 Mar 11 @ 5:45 pm
Is the DXM pro mixer also a midi controller? If it's not, you have to use it as an external mixer. Go to sound settings and select External Mixer with the Numark ASIO driver. Then plug in the master v7 (the slave one can't processs audio) into the mixer and it should work fine. Even though the crossfader will not move in the program, it still works because you are mixing just like you would with 2 cd decks or turntables.
geposted Mon 28 Mar 11 @ 1:39 am
If you wish to video crossfade, then you will need an external mixer that is MIDI capable.
Or you can map a knob or slider on your V7's that you don't use to perform video crossfading.
Or a button to perform an automatic transition when pressed (Map it to video_transition)
geposted Mon 28 Mar 11 @ 9:03 am
