Im getting a Video driver error message,and it wont activate !!!HELP!
geposted Sat 26 Mar 11 @ 10:39 pm
Could it be because i deleted winamp? got tired of winamp taking over all related files,plus the tool bar in my browser...but looks like it took a video driver along with it...
geposted Sat 26 Mar 11 @ 10:47 pm
O.K. did a restart and it came back...what happened? just before it sayd usb device driver error...(that would be my mini hub or the 2 recievers for the wireless mouse & keyboard )...tried a diferent usb on the left of the Lappy for the RMX..that did'nt work...
geposted Sat 26 Mar 11 @ 11:20 pm
always try the simple things first.never change rmx usb connection unless you have drivers on cd/flashdrive as rmx will play on the input you install it on.
secondly check all outputs ie make sure your hardware is selected for tv output.in video options make sure you dont check/uncheck something by mistake and again check to see if your hardware is in the dropdown section and is selected.
now check usb hub conections one by one.
do you only use lappy for gigs or to work(download).
for me i only use for gigs so when i connect my rig up and turn power on all my settings are there just to be selected like plug and play
geposted Sun 27 Mar 11 @ 3:15 am
Thanks Staffy...yeah i had moved the Rmx to the top usb ( over the bottom usb now for the hub) but it workrd prior..so... i have been experiencing popup warnings that the usb device ( in this case the hub ) is not recognized right after turning the lappy on...but after a minute or so its working...
geposted Sun 27 Mar 11 @ 3:34 am
check the drivers that the hub is using to make sure it working properly.
im not to experienced in tech stuff but the suggestions i give come from my own experience lol.
then as you say it seems like hub requires warm up time so load up lappy first make all your settings in vdj and select then restart lappy again and all should be good
geposted Sun 27 Mar 11 @ 4:04 am
