hi
going to buy a 4channel mixer.things i looking are
1.should be below - 1250US$
2.super midi ability
3.4output soundcard
4.quality sounds
my setup going to be 2 Numark V7s and 4channel mixer with vdj 4deck play
if thers a controller can do the things i mention above i would like to take a midi controller to the middle.......
please give me a good choice.....?
thanks.
3.4output soundcard
4.quality sounds
thanks.
geposted Sat 26 Mar 11 @ 11:13 pm
Im a huge fan of the Denon line
DN-X600, DN-X1600 and DN-X1700
The Allen & Heath xone 92 is good also with great sound quality but not everything on the mixer is midi, i also owned an allen & heath xone 3D and i loved it, crazy amount of midi but the jog wheels on the unit left much to be desired.
geposted Sat 26 Mar 11 @ 11:39 pm
The Denon X1600 Mixer is Great but if you are a heavy handed DJ, I dont recomend buying it. The up faders are not sturdy will get loose because they are being suported by just two small screws. The DJM 700 is another good mixer and its alittle tougher. You also have the Ecler which is great.
geposted Sun 27 Mar 11 @ 12:08 am
mate im using the pioneerdjm 500 for over a year now and looovvveee it.never had an issue evening changing connections or swapping channels with vdj playing.
if you want all knobs buttons ect fully mappable.
also option of 4 mic inputs with added effects for karaoke ect
geposted Sun 27 Mar 11 @ 3:02 am
