Hi There
Can someone help me Out.
What do you do after you Modified the XML file of a Skin.
I've made a change in the code and saved it, but I still don't see the update on the Skin when I bring it up (use it).
What STEPS I'm I forgetting to do.
Thanks in Advance
Jose
Thanks in Advance
Jose
geposted Sun 27 Mar 11 @ 3:41 am
well that depends on what it was you rewrote and many things.those it make a change or require a graphical change on the Bitmap file? or do have to to change the controllers syntax,midi mapping or ?? you need to be more specific.did you re-safe the xml file and overwrite the old? (you would see a popup requesting an answer to rewrite or not) im just wondering if in fact you are accessing the right file (is it name the same as the Bitmap?) ie= the one you've programmed ...
geposted Sun 27 Mar 11 @ 3:55 am
All I Did was,
I Reversed the order for Displaying the Name of the Song Playing from "%Author - %Title TO %Title - %Author"
I would think this is No Big Change.
YES, The Changes were Saved.
Thanks
Jose
Thanks
Jose
geposted Sun 27 Mar 11 @ 4:16 am
You have to Zip the xml and the bmp file again and place that file at MyDocuments/VirtualDJ/Skins Folder. After that, goto config Skins Tab and choose that skin again.
geposted Sun 27 Mar 11 @ 10:21 am
THANKS DJdad
I zipped the XML & BMP files back to the proper Folders (Skin).
IT NOW WORKS..
BTW: If you don't zip the BMP file (I made no changes to this file), you Get an INVALID SKIN FILE (error line 0 in the XML) ERROR message (windows box).
Thanks again for your help.
Jose
IT NOW WORKS..
Jose
geposted Sun 27 Mar 11 @ 1:46 pm
I just installed Virtual DJ Pro 7.0.4 (I upgraded from a retail purchased Home Edition 6) and found out that none of my former skins were valid: all gave the "error line o" message! After an afternoon of trial and error I found out that the skin files (xml and bmp) now have to be compressed in one zip file.... and not by any random program either: Windows XP's internal zip utility, WinRar and 7Zip are no good. Only WinZip zip files are accepted by my version of Virtual DJ. Does anyone have the same experience?
Also: I have only been able to load the default skins that come with Virtual DJ. For testing purposes (to find out what program could make the right zip files) I unzipped and rezipped a default skin. I have made (and continuously improved) a TOUCH SCREEN SKIN with which I am very satisfied, but alas: it won't work with 7.0.4. Has anything changed in the scripting protocol that I should be aware of?
As soon as I get my skin working, I'll upload it. Maybe there is someone else out there who is like me (DJ-ing without any external hardware, just one single touch screen to do it all) and who will have some use for it too...
geposted Mon 06 Jun 11 @ 4:08 pm
