Topic: 4 MX Mapper help?
I need parameters To assign my Jogs to parameter 2 for FX on my 4-mx? any help?
geposted Mon 28 Mar 11 @ 9:03 am
Change the jogwheel (JOG) mapping to:
deck active effect active ? device_side 'left' ? deck active effect slider 1 : deck active effect slider 2 : touchwheel
Add the the jogwheel touch (JOG_TOUCH) to the following:
deck active effect active ? hold off : touchwheel_touch
Does this hold off action do the same thing as scratch_hold off, as i don't see any infos in the List of Verbs (Wiki).
It switches the scratch hold off if it's on, so you don't end up with the scratch hold jammed on while adjusting the effect.
It may now be depreciated - scratch_hold should be the same, or possibly touchwheel_touch off
thank you!
ok one thing. it works fine but when you activate an effect, both jogs are assigned to parameter 2 so if delay is activated on deck 1, parameter 2 is also on jog 2 while i need to nudge
In this case assign this as Jogwheel
effect active ? effect slider 1 : touchwheel
or
effect active ? effect slider 2 : touchwheel
to control the 2nd parametr
but this means that you can control only ONE parametr the slider 1 or the slider 2, depending which code you will choose.
For the JogTouch try this..
Does anybody know how to install the Grafx on your Virtual Dj?
much thanks!
