Not sure if anynone has pointed the following suggestion: could the programmers make it so it would be possible to drag and drop a sample onto the Sampler, as far as I have seen the only way to this is to Load it with a few clicks. It would be so much easier to just drag and drop it from the Browser instead. Anyone agree?
geposted Tue 29 Mar 11 @ 12:50 pm
This should probably go in the Wishes and New features forum >>> https://virtualdj.com/forums/18/Wishes_and_new_features.html
There really is no reason to have this feature when you can drag and drop a sample into one of the possible 99 decks. Keep in mind with the sampler, you also have to create the sample before you can load it (unless it is one of the pre-loaded or downloaded from the samples page).
The 6 deck skin is a great option for dragging and dropping samples.
Regards,
AC
Regards,
AC
geposted Tue 29 Mar 11 @ 2:13 pm
