Hi, having previously had a hercules basic controller running with le, i've purchased a numark mixtrack pro, I have been using it on my friends full version of vdj to get a feel for it and to see if i should take the plunge and upgrade to pro or use the traktor bundled with it, my problem is, after a couple of on and offs with software hardware etc, i lose the scratch and pause with the touch jog wheels, checked options that vinyl is selected, all seems fine. Strangely when i put the controller into a new usb port it works again properly but then happens again..and again etc.
Any ideas? its really put me off going pro! All help gratefully recieved :)
geposted Wed 30 Mar 11 @ 4:58 pm
I believe VDJ update 7.03 addresses hardware issues with a couple different controllers. Try updating the software in the downloads section.
Hope that helps.
AC
Hope that helps.
AC
geposted Thu 31 Mar 11 @ 12:34 am
